1 Senaste redigerad av jonasolof (2017-11-02 09:35:41)
Tråd: Ny: AVM 6890 klarar fiber, adsl och 4G/3G failover för DSL
Efterföljare till nu gamla 6840
At IFA AVM is debuting the FRITZ!Box 6890 LTE for fast Internet with up to 300 Mbit/s via mobile network or DSL. The new model transmits on five LTE and two UMTS frequencies and supports roaming for surfing in all mobile communication networks. Like the new FRITZ!Box models 7590 and 6590 Cable, the FRITZ!Box 6890 LTE is very well-equipped for home networking: fast wireless LAN on both frequencies and with the new Multi-User MIMO technology (4x4 dual band Wireless AC+N with 1,733 Mbit/s on 5 GHz and 800 Mbit/s on 2.4 GHz), four gigabit LAN ports, one USB port for storage media and one DECT base station for phones and Smart Home applications. Existing telecom systems can be connected over the internal ISDN S₀ bus. Analog telephones, fax machines or intercom systems can also be connected to the new FRITZ!Box. The FRITZ!Box 6890 LTE can be used either via mobile communications or on the landline. It can be connected to the DSL line directly or via the WAN port on a cable or fiber optic modem. Thanks to the fallback function from DSL to mobile communications featured by the FRITZ!Box 6890 LTE, users with especially high demands on Internet availability benefit from additional security. Download rates of up to 300 Mbit/s can be achieved via both LTE (CAT6) and DSL (from ADSL to VDSL2 with 35b supervectoring). IP-based (SIP standard) telephony is supported for all connection types. On top of this, the FRITZ!Box 6890 LTE can also be used on ISDN and analog landline connections
Routern kan som framgår ovan användas med adsl eller kopplad till kabelmodem eller fiber-mediakonverter. Om DSL synkronisering faller ifrån går routern över till 4G eller 3g. Funkar således inte om WAN-porten är ansluten till mediakonverter för fiber.
Här lite mer info på tyska
https://www.homeandsmart.de/avm-fritzbo … -wlan-mesh
6890 ska komma (i Tyskland under Q4. Pris ca 350 euro).
2 Senaste redigerad av jonasolof (2017-11-02 09:13:54)
Sv: Ny: AVM 6890 klarar fiber, adsl och 4G/3G failover för DSL
De band som finns i routern är alla aktuella som används för FDD: 1 (2100), 3 (1800), 7 (2600), 8 (900) och 20 (800). Det aviserade 700 bandet är inte med vilket torde bero på att regelverket för 700-bandet inte var klart då produkten togs fram. På tyska siten LTE-anbieter.info noteras ett europeiskt 700 band men enbart för TDD, då med nummer 28. Huruvida 700 bandet kommer att användas för FDD också förefaller oklart. PTS aviserar tilldelning av dubbelblock, dvs FDD:
http://www.pts.se/upload/Remisser/2017/ … 00_MHz.pdf
AVM har hittills inte tagit fram några routrar för TDD.
