Tråd: DOVADO Firmware 7.0 till PRO / DOMA / GO / TINY
Greetings everyone!
We have been VERY busy these past couple of months. A lot of firmware development, testing, fixing and planning. Well, today we have mustered up our confidence and released firmware version 7.0! This firmware release is limited to the DOVADO TINY / GO / DOMA / PRO router models. It is not available for the DOVADO 4GR as this model has been discontinued and succeeded by our 3rd generation dual-USB port router; the DOVADO PRO. It is the world’s fastest router for USB modems, handling 4G modems at FULL 150Mbps speeds. All of the details and speed tests for this model are available in our short demo video: http://www.youtube.com/dovado
So what’s new in firmware 7.0, you wonder?
For starters, we have implemented a PPTP-based VPN client! SURPRISE!
This will allow you to connect all/any devices at home or office to a remote VPN server. VPN will provide you a secure virtual pipe between your router and the remote server it is connecting to, making sure that nobody can eavesdrop on your precious data packets as you work from home or abroad. There are countless uses of VPN which many of you know about already, so we will not need to dive too much into this topic.   ;-)
Please note that (for now), the Connection Tracker is disabled when using VPN straight out of the router. We are working on a long-term happy relationship between these two features. So, if you have any critical applications that require a permanent Internet uptime, please do not rely on VPN as we cannot assure it to work perfectly. It’s on our to-do list.
Here’s a quick video on how to configure the PPTP-based VPN Client:  http://www.youtube.com/watch?v=O9bCpUj_wYM
Second, as you already realized over the past 5 years, we are nuts about SMS! Therefore, we have implemented a really, really, really cool time-saving SMS command: “upgrade”
Once you have enabled this SMS command in the SMS->REMOTE CONTROL page, you’ll be able to send an SMS to your DOVADO router from any old phone, instructing the router to download the latest firmware from our servers! This will make life a lot easier for you when you receive a notification from the router that there’s a new firmware available. It’ll also simplify upgrades for those of you who have many routers out in the field, via a group SMS.
Here’s a video recap of all the SMS features that are available in firmware 7.0: http://www.youtube.com/watch?v=UUE_lbPm6vU
We hope you enjoy this firmware release as much as we have enjoyed preparing it!
Firmware is available from http://www.dovado.com/firmware
PS: The Live Upgrade method will be out in a week or two.
Wishing you a happy summer with 7.0!
/Team DOVADO
Join our Facebook Group!: https://www.facebook.com/groups/24907812089/
Tweet-tweet? http://twitter.com/dovado
YouTube: http://www.youtube.com/dovado
Need tech support? http://www.dovado.com/en/support/support-form
Sv: DOVADO Firmware 7.0 till PRO / DOMA / GO / TINY
Hej Sam,
Jag gjorde en upgrade till version 7.0 på min Tiny via Http upgrade(Bin fil).
All gick bra men, mitt modem Huawei E3276 Telia(ej Hi-link) vill inte koppla upp.
Gjorde 2 omstarter fortfarande samma sak hittar modemet men det är disconnected och fast jag trycker på connect så kopplar det inte upp.
Enligt loggen så hittar den modmet och gör switchen samt kommunicerar med modemet vilket är ok,tilldelar den Ip adress sedan så händer inget mer.
Prövade med Reset knappen 2ggr men det funkar inte.
Fick sätta in modemet i min gamla Tp-link MR3420 med Open Wrt för att kolla så det inte var något fel på modmet och nätet, den kopplade upp på 4G nätet utan problem.
Har du något bra tips på vad det kan vara.
Tack på förhand
Mvh Patrik
Kolla att APN är fortfarande där. Finns det någon PIN kod på plats?
Tack,
Sam
Den står bredband.tre.se. Jag pin kod disabled
5 Senaste redigerad av plun (2013-07-10 12:45:20)
Har semester och har just roat mig med Tinyn.... smile
Samma strul som för thomson69
Kollar man loggen så blir det galet med detekteringen, drar man ur modemet och sätteri det igen så blir det rätt.
(Sen fick jag till en alldeles galen flashning eftersom jag har Tinyn som brygga men det är en annan femma som löste sig)
EDIT loggen
Jan  1 00:00:09 info System: The router has started!
Jan  1 00:00:03 info USB: Detected item at boot: Vendor=0x1a40, Product=0x0201
Jan  1 00:00:04 info USB: Detected item at boot: Vendor=0x1a40, Product=0x0101
Jan  1 00:00:05 info USB: Detected item at boot: Vendor=0x12d1, Product=0x1506
Jan  1 00:00:08 info USB: Detected new item: Vendor=0x12d1, Product=0x1506
Jan  1 00:00:09 info USB: Detected new item: Vendor=0x1a40, Product=0x0101
Jan  1 00:00:09 info USB: Detected new item: Vendor=0x1a40, Product=0x0201
Jan  1 00:00:27 info Modem: Communication test with modem OK.
Jan  1 01:00:41 info USB: Detected new item: Vendor=0x12d1, Product=0x14fe
Jan  1 01:00:43 info USB: Detected new item: Vendor=0x12d1, Product=0x1506
Jan  1 01:00:58 info Modem: Communication test with modem OK.
Jan  1 01:03:10 info USB: Detected new item: Vendor=0x12d1, Product=0x14fe
Jan  1 01:03:12 info USB: Detected new item: Vendor=0x12d1, Product=0x1506
Jan  1 01:03:26 info Modem: Communication test with modem OK.
Jan  1 01:03:36 info Modem: Modem has registered to the 4G-network.
Jan  1 01:03:41 info Time zone: No timezone configured. Configuring it now!
Jan  1 01:03:41 info Time zone: Setting autodetected continent (Europe) and time zone (Sweden-Stockholm).
Jan  1 01:03:41 info APN: APN already configured. No need to scan!
Jan  1 01:03:41 info Modem: Connecting modem using APN: internet.telenor.se Authentication method: Both
Jan  1 01:03:43 info DHCP Client: Lease of 79.XX:XX:XX has been obtained, lease time 518400 seconds.
Jan  1 01:03:45 info DHCP Client: Using DNS servers from DHCP (not custom)...
Jan  1 01:04:09 info Bridge: Will try to set date before entering bridge mode.
Jul 10 13:54:28 info Bridge: We got date. Entering bridge mode...
Jul 10 13:54:28 info Time zone: No timezone configured. Configuring it now!
Jul 10 13:54:29 info Time zone: Setting autodetected continent (Europe) and time zone (Sweden-Stockholm).
Jul 10 13:54:29 info APN: APN already configured. No need to scan!
Jul 10 13:57:48 info USB: Detected new item: Vendor=0x12d1, Product=0x14fe
Jul 10 13:57:50 info USB: Detected new item: Vendor=0x12d1, Product=0x1506
Jul 10 13:57:56 info SIM: PIN code is enabled on SIM card.
Jul 10 13:58:03 info USB: Detected new item: Vendor=0x12d1, Product=0x1506
Jul 10 13:58:17 info Modem: Communication test with modem OK.
Jul 10 14:00:23 info USB: Detected new item: Vendor=0x12d1, Product=0x14fe
Jul 10 14:00:25 info USB: Detected new item: Vendor=0x12d1, Product=0x1506
Jul 10 14:00:38 info Modem: Communication test with modem OK.
Jul 10 14:00:54 info Modem: Modem has registered to the 4G-network.
Jul 10 14:00:58 info Time zone: No timezone configured. Configuring it now!
Jul 10 14:00:59 info Time zone: Setting autodetected continent (Europe) and time zone (Sweden-Stockholm).
Jul 10 14:00:59 info APN: APN already configured. No need to scan!
Jul 10 14:00:59 info Modem: Connecting modem using APN: internet.telenor.se Authentication method: Both
Jul 10 14:01:02 info Bridge: Bridge has connected to ISP.
Jul 10 14:01:05 info Time zone: No timezone configured. Configuring it now!
Jul 10 14:01:06 info Time zone: Setting autodetected continent (Europe) and time zone (Sweden-Stockholm).
Jul 10 14:01:06 info APN: APN already configured. No need to scan!
Jaha....TRE SIM i Telia E3276. Har du provat i 3G-ONLY läge?
Testade nu factory reset på DOVADO TINY 7.0fw + Telia E3276 + TRE SIM. Funkar, kopplar upp på 3G.
Modemet har firmware 21.192.03.01.07
Vad har du på din?
Tack
Vad har du på din?
Tack
Hej, jag har samma firmware på min sticka.
Har prövat att sätta den på 3g only men inget händer.
Ingen lampa på modemet lyser, verkar som den inte får ström?
Har prövat att göra reset på Tiny utan framgång.
Vad händer om du backar till 6.2.7?
Ska strax testa
Har nergraderat till 6.2.7 och nu så kopplar modemet upp.
Var god att fylla in http://www.dovado.com/sv/support/supportformular
Mina kollegor kan ta en närmare titt på detta. Min kopplar upp via 7.0. Hmmmm...
Tack,
Sam
Hej Sam,
Testade att uppgradera via exe fil nu till 7.0 och nu så fungerar det, skumt.
//Patrik
14 Senaste redigerad av idgforum (2013-07-11 11:10:00)
För mig fungerade det (TINNY + TRE 3G +  E372). Kopplade på VPN och funkade fint det med.
Kör Telenor med E398 endast på 3G, uppgraderade till 7.0.0 och modemet kopplar inte upp...
Uppgraderade via exe fil.
Log:
Jan  1 00:00:08 info System: The router has started!
Jan  1 00:00:06 info USB: Detected item at boot: Vendor=0x12d1, Product=0x1505
Jan  1 00:00:07 info USB: Detected new item: Vendor=0x12d1, Product=0x1505
Jan  1 00:00:15 info USB: Detected new item: Vendor=0x12d1, Product=0x1506
Jan  1 00:00:23 info DHCP Server: Client with MAC address xx:xx:xx:xx:xx:xx got IP 192.168.1.57
Jan  1 00:00:26 info DHCP Server: Client with MAC address xx:xx:xx:xx:xx:xx got IP 192.168.1.5
Jan  1 00:00:38 info Modem: Communication test with modem OK.
Sedan inget mer på 5 minuter.
Kopplat in min TP-link med Open WRT igen, kanske får nergradera till 6.2.7 på Tinyn så jag kan ha den som backup.
16 Senaste redigerad av plun (2013-07-12 09:00:18)
Prova som jag gjorde att bara dra ur och sätt i modemet igen.
dvs efter att man fått   " Modem: Communication test with modem OK."
Log:
Ser ut som det felet som jag hade när jag uppgraderade till version 7.0.0.
Hade prövat att göra Factory reset med version 7.0.0 inladdat men det fungerade inte.
Jag nergraderade till 6.2.7, efter detta var gjort så betedde sig routern som om man hade gjort en Factory reset.
Fyllde i allt rebootade allt fungerade.
Efter ca 10 min tid så testade jag att uppgradera till 7.0.0.  Efter denna flash så  fungerade allt som det skulle.
18 Senaste redigerad av Viperj (2013-07-17 22:01:28)
Jag har idag uppgraderat via live update till 7.0.2 på min tiny.
Har samma problem som Nybom (fast jag har Telia och Huawei E3276). Gjorde som plun rekommenderade och drog ur modemet efter routern bootat klart och fått "Communication test with modem ok". Efter jag satte i modemet igen så kopplade den upp på 4G på direkten. Så för stunden funkar det, men om kopplingen går ner och Connection tracker bootar om routern så kopplar den inte upp igen...
Några förslag på vad göra för att slippa jobba med denna work around?
Tog mig tid att uppgradera till 7.02 och anslutningsproblemet kvarstår trots att Dovado uppdaterat två gånger!
Har inga tips annat än att dra ur modemet som tidigare.
Har ni provat 7.0.3 än, via Live Upgrade?
Ja, både Tiny med e3276, och Pro med e392 - klockrent !
Yep, funkar ej!
Men kollade loggen igen som är postad tidigare och funderade kring detekteringen.
Jag kör ju med en USB-hub samt en aktiv USB-kabel eftersom jag tycker allting blir stabilare inkl att jag kan labba med rooter.
Kollar man loggen samt googlar lite
Är ju huben !
Sen drar jag ur modemet och sätter i det igen så detekteras det rätt
Jan  1 01:00:12 info USB: Detected new item: Vendor=0x12d1, Product=0x14fe
Jan  1 01:00:14 info USB: Detected new item: Vendor=0x12d1, Product=0x1506
och modemet hoppar snällt igång och är "rock-solid" efter det!
Uppgraderade till 7.0.3 igår. Samma fenomen, dvs modemet kopplar inte upp efter uppgraderingen. Inte heller efter att routern har gjorts strömlös och startats upp igen. Däremot kopplar modemet upp så fort man har routern bootad och klar och därefter drar ur modemet och sätter i det igen. Har nu varit helt stabil de senaste 10 timmarna utan att Connection tracker har startat om.
Installerade firmwareversion 7.04 nu på morgonen och nu funkar det igen!  smile
Har också uppdaterat till 7.0.4 och nu kopplar den upp på 4G av sig själv direkt efter FW uppgraderingen. Har den inte gjort med någon tidigare variant av version 7 FW utan att man har tagit ur modemet och satt i det igen medan routern har varit bootad.
