Tråd: testlägen android
*#*#4636#*#* – Phone Information (allows you to change the SMS service centre number and more)
    *2767*3855# – Factory Reset Phone
    *#*#34971539#*#* – Shows completes information about the camera
    *#*#7594#*#* – Changing the power button behavior – Enables direct power off
    once the code enabled
    *#*#273283*255*663282*#*#* – For a quick backup to all your media files
    *#*#197328640#*#* – Enabling test mode for service activity
    *#*#232339#*#* or *#*#526#*#* or *#*#528#*#* – Wireless LAN Tests
    *#*#232338#*#* – Displays Wi-Fi Mac-address
    *#*#1472365#*#* – For a quick GPS test
    *#*#1575#*#* – A Different type GPS test
    *#*#0283#*#* – Packet Loopback test
    *#*#0*#*#* – LCD display test
    *#*#0673#*#* or *#*#0289#*#* – Audio test
    *#*#0842#*#* – Vibration and Backlight test
    *#*#2663#*#* – Displays touch-screen version
    *#*#2664#*#* – Touch-Screen test
    *#*#0588#*#* – Proximity sensor test
    *#*#3264#*#* – Ram version
    *#*#232331#*#* – Bluetooth test
    *#*#7262626#*#* – Field test
    *#*#232337#*#* – Displays bluetooth device address
    *#*#8255#*#* – For Google Talk service monitoring
    *#*#4986*2650468#*#* – PDA, Phone, Hardware, RF Call Date firmware info
    *#*#1234#*#* – PDA and Phone firmware info
    *#*#1111#*#* – FTA Software version
    *#*#2222#*#* – FTA Hardware verion
    *#*#44336#*#* – Displays Build time and change list number
    *#06# – Displays IMEI number
    *#*#8351#*#* – Enables voice dialing logging mode
    *#*#8350#*#* – Disables voice dialing logging mode
    **05***# – Execute from Emergency dial screen to unlock PUK code
Sv: testlägen android
Kan man se LTE intrafrequency neighbor cells? Interfrequency neighbor cells? Anges SINR, CN och CQI?
kan inte påstå att jag använder det så mycket,
mest pga den fw jag har
men har du en std lur så kan du prova.
provar nya firefox på android, grymt mycket bättre.
denna är bra:
**05*<puk nummret>*<nya pin>*<nya pin igen>#
snabbt fixxa ny pin :-)
Jag testade några av koderna som G-man gav i post ovan. funkar inte på en galaxy G4.
