Tråd: Open WRT för TP link ger LTE modem full hastighet
Hittade denna sida på nätet.  http://www.rfactory.org/OpenWRT/
Dom jobbar med att man ska få full LTE hastighet på TP-Link routers.
Supported Routers
Initially, this project used the TP-Link MR3420 router as it's testbed but the techniques that were developed did not rely on any specfic features of that router. Instead, any router with a USB port, at least 4meg of flash RAM and is supported by OpenWRT can be used. A custom firmware must be created for each model of router.
Routers that have custom firmware available :
Router Model
TP-Link MR3420
All V1 models supported. V2 models are not supported.
TP-Link WR703N
All V1 models including V1.7 are supported.
TP-Link MR3020
TP-Link MR3220    All V1 and V2 models supported.
Firmware for other routers can be created on request.
Supported Modems
One of the goals of this project was to allow LTE modems to run at full LTE speeds when used with the custom firmware. Many commercial routers support LTE modems but the maximum speed is limited to 25mbs. With the firmware developed here many LTE modems can be used at full LTE speeds.
The supported and tested modems are :
4G Modems
ZTE 821
Tested at full LTE speeds.
Sierra 320U/330U    Tested at full LTE speeds. Also supported with GPS enabled.
Huawei E398/E389/E392    Tested at full LTE speeds.
3G Modems
ZTE MF633
ZTE MF668
Alcatel AL720    Not currently supported by ModemGUI but will be in future.
Vodafone K4505
Huawei E160X
Huawei E1762
BP3-EXT    This modem is not supported by ModemGUI.
Sierra 312U    Will run at HSPA+ speeds of 42mbs
Huawei E353
Other modems may work with with the current firmware but have not been specifically tested. These modems should work with the firmware as support is built-in for them but they have not been tested.
Sierra 313U    Will run at full LTE speeds
Sierra 319U    Will run at HSPA+ speeds of 42mbs
Sierra 754S    Will run at full LTE speeds
ZTE MF820D/821D    Will run at full LTE speeds
ZTE MF622/627/628/632
ZTE MF636/638/645/662
Huawei E3276    Will run at full LTE speeds
Sierra 305/306/307/308/310
Most older Huawei 3G models
Huawei E367/E372
Sv: Open WRT för TP link ger LTE modem full hastighet
Mycket bra info som jag klistrade. Ändrade rubriken till mer specifik.
Det står att man kan kommunicera med modemet i routern med ett windowspaket. Vore fint om man kan skicka AT kommandon.
3 Senaste redigerad av thomson69 (2013-03-01 12:04:43)
Lägger även till dessa sidor
http://whirlpool.net.au/wiki/router_openwrt
http://www.rfactory.org/3G/index.html
Adding Custom Commands to ModemGUI
ModemGUI supports two user defined data displays called Custom Commands. This feature allows the user to specify certain AT-Commands to be sent to the modem and to display specific parts of the response.
Custom Commands can be created only after you have connected to the router and modem. The buttons associated with Custom Commands are disabled until then.
http://www.rfactory.org/OpenWRT/custom.html
Ska ta med mig det till Cebit och se om någon på Huawei känner för att tala om vilka AT kommandon som finns för t ex E392. Fr a intra frequency neighbors.
Redan att absolute radio channel number kan visas är bra.
5 Senaste redigerad av Mario (2013-03-02 11:06:00)
Har haft koll på dessa sider med ett tag.
Får hoppas openwrt släpper en officiell firmware till 3420 v2 så att dairyman kan modda den.
Kör med denna på min
https://forum.openwrt.org/viewtopic.php?id=41326
Men den funkar med gamla drivrutiner för modemet så max ca 25 mb.
Det är stor risk att bricka routern så lägg inte in den en om ni inte har lust att löda och har möjlighet att återställa vi seriel adapter.
BBB via Telenor 2st Poynting riktantenner Tp-link mr3420v2 med avstängd wifi huawei 398 & 392 och E3276
Asus rt-56u körs som router och delar ut till 11 enheter. (Tiny routern körs numera i sommarstugan)
Klarar V1 4G modem med OpenWRT? Uppenbarligen.
Jag har testat med mitt ZTE MF820D och MR3420 v1 på Tre:s 4G nät här i Malmö kommer upp i ca 30-38Mbit ner och 15-18Mbit upp. Detta är testat med den senaste firmwaren i från denna sida http://www.rfactory.org/OpenWRT/
intressant..... får plocka fram min 3420 V1 och provköra med e392 o e398
Kör nu med Mr3420 V1 med Huawei e398 modem med telenor 4g ab
kan bara bekräfta att det fungerar utan problem
10 Senaste redigerad av plun (2013-03-10 17:04:01)
Kom på att jag hade ett 3220-modem liggande smile  (sommarstugeroutern)
Sep  8 16:10:53 OpenWrt user.notice usb-modeswitch: 1-1:1.6: Manufacturer=Huawei_Technologies Product=HUAWEI_Mobile Serial=? 12d1 1506 1
Sep  8 16:11:24 OpenWrt user.notice sierra_set: SierraSet is running qmihelp
Sep  8 16:11:24 OpenWrt user.notice qmihelp : wwan1: ===Starting QMI script===
Sep  8 16:11:24 OpenWrt user.notice qmihelp : wwan1: Will use /dev/cdc-wdm1 as management port
Sep  8 16:11:35 OpenWrt user.notice qmihelp : wwan1: Qmi Revision: M9200B-SCAQWBZD-3.3.330155T 1 [Aug 09 2012 23:00:00]
Sep  8 16:11:35 OpenWrt user.notice qmihelp : wwan1: Script Command : start
Sep  8 16:11:35 OpenWrt user.notice qmihelp : wwan1: Attempt to Start Network
Sep  8 16:11:35 OpenWrt user.notice qmihelp : wwan1: Checking Pin Status
Sep  8 16:11:38 OpenWrt user.notice qmihelp : wwan1: PIN1 status is : disabled
Sep  8 16:11:39 OpenWrt user.notice qmihelp : wwan1: Attempting to Connect ....
Sep  8 16:11:45 OpenWrt user.notice qmihelp : wwan1: Connected to Network
Sep  8 16:11:45 OpenWrt daemon.notice netifd: wan (10731): Sending select for 79.102.13.XX...
Sep  8 16:11:45 OpenWrt daemon.notice netifd: wan (10731): Lease of 79.102.13.XX obtained, lease time 7200
Sep  8 16:11:45 OpenWrt daemon.notice netifd: Interface 'wan' is now up
Sep  8 16:11:48 OpenWrt user.info firewall: adding wan (wwan1) to zone wan
Sep  8 16:11:50 OpenWrt daemon.info dnsmasq[1278]: reading /tmp/resolv.conf.auto
Sep  8 16:11:50 OpenWrt daemon.info dnsmasq[1278]: using nameserver 195.54.122.211#53
Sep  8 16:11:50 OpenWrt daemon.info dnsmasq[1278]: using nameserver 195.54.122.221#53
Sep  8 16:11:50 OpenWrt daemon.info dnsmasq[1278]: using local addresses only for domain lan
Just nu är det stortankningstider men över 30 Mbits kommer jag upp till smile
Sen är det här det magiska
Ska fråga Merlin om det..... smile
Med risk för att vara lat och inte läst manualen eller hela tråden... smile
Jag får inte upp fullständig info med modemGUIet, får ni andra det ??
Likadant med både E392 samt E398.
http://i.imgur.com/S2kIauUl.png
12 Senaste redigerad av Jonny (2013-03-10 18:08:08)
hittar inget sådan info om signalstyrkor eller dyligt......endast dx o tx
http://forumbilder.se/CDLJB/openwrt.jpg
13 Senaste redigerad av plun (2013-03-10 18:04:55)
Jo modemguiet är ett separat program som loggar in i routern och hämtar info från modemet.
http://www.rfactory.org/OpenWRT/modemgui.html
Nu har jag läst manualen och hittar inget där om min fundering.
aha....ska kolla
Jonny skrev:
aha....ska kolla
Jo ett riktigt kanonverktyg om allt funkade  smile
Sen kan man enkelt lägga till egna kommandon.
16 Senaste redigerad av Jonny (2013-03-10 18:31:35)
får ingen info vid connection..... bara unknown o ? på allt
17 Senaste redigerad av plun (2013-03-10 18:38:21)
Har du satt ett lösenord för routern ?
Logga sedan ut ur routern.
Sen samma lösen i modemguiet.
Jag fick sedan ändra modemporten till manuell inställning dvs till ttyUSB0.
Sen funkade det.
jo allt är ok men funkar ej... antingen som ovan eller modem not found=ingen info
Jo om du kommer in i GUIet utan felmeddelande så kopplas du upp mot routern, sen är det att hitta rätt port.
Jag fick avsluta mitt roande söndagsexperiment pga av andra användare men det är klart häftigt att en 200kr-router kan bli en rolls-royce  smile  Körde två timmar utan några trubbel och inte märkbart hett heller.
Sen heter det inte router med det här firmwaret utan "ROOter"  smile
Hittar inget kontaktväg till snubben som knådat ? Han är värd lite sponsring !
Vore trevligt att se  modem GUI på 4G.
Nu gäller det att få tag i AT kommandot för en operatörslista. Det ska gå, åtminstone på 3G.
Jo men jag postade ju skärmskottet ovan via min 4G-anslutning.  Men jag får inte all info och en till detalj är att jag inte kan välja enbart 4G med Connection > "Mode"-rullgardinen.  Huawei-knas ??
Hur man lägger till custom commands
Snubben som knådat måste ju husera någonstans ??  eller är han en sådan som enbart syns på IRC ??
Hursomhelst så får fler testa hur det ser ut med deras modem.
Personen går under detta alias "Dairyman"  kolla på denna sida http://forums.whirlpool.net.au/forum-re … ?t=2036176
Skärmskottet visar UMTS parametrar. Det ska vara RSSI, RSRP och RSRQ på LTE.
24 Senaste redigerad av plun (2013-03-11 18:48:50)
Jo det kanske var en 3G...??? men förbenat bra sådan isåfall.
PoC (fotade mitt experiment)
http://i.imgur.com/8MHLkmE.jpg
@thomson69
Tack för infot om dairyman,  kollar vidare.
EDIT
http://whirlpool.net.au/wiki/router_openwrt       smile
Huga, vilken tråd... part 2
Troliga buggen.
I am pretty sure dairyman will have to upgrade the LTE bandmasks as Jhend posted:
jhend writes...
B1 (2100 MHz FDD) 1
B3 (1800 MHz FDD) 4
B7 (2600 MHz FDD) 40
B8 (900 MHz FDD) 80
B20 (800 MHz FDD) 80000
B40 (2300 MHz TDD) 10000000000
before it will work as I know he has done the Australian and Canadian ones. Im sure its a pretty simple task to add them to the script.
Good, I was starting to look for this so I could update ModemGUI to use 4G for the Huawei modems.
Now I don't have to look and can actually do some work. smile
smile
337ms ping... :-)
