Tråd: lite sent tänkt, men....
http://www.idg.se/2.1085/1.174085
Sv: lite sent tänkt, men....
Sitter ute på landet just nu, UMR'en står på övervåningen, modemet sitter tejpat ute på väggen med en 2 m sladd som går in till routern.
Och det går i hiskerliga hastigheter som typ 0,1mbit/s.
Körde en tptest nu och fick 0,2 / 0,09.
Reply from 192.36.125.18: bytes=32 time=2877ms TTL=249
Reply from 192.36.125.18: bytes=32 time=4017ms TTL=249
Reply from 192.36.125.18: bytes=32 time=627ms TTL=249
Request timed out.
Request timed out.
Reply from 192.36.125.18: bytes=32 time=1977ms TTL=249
Reply from 192.36.125.18: bytes=32 time=1631ms TTL=249
Reply from 192.36.125.18: bytes=32 time=2252ms TTL=249
Reply from 192.36.125.18: bytes=32 time=3904ms TTL=249
Request timed out.
Reply from 192.36.125.18: bytes=32 time=4427ms TTL=249
Reply from 192.36.125.18: bytes=32 time=3319ms TTL=249
Reply from 192.36.125.18: bytes=32 time=1126ms TTL=249
Reply from 192.36.125.18: bytes=32 time=232ms TTL=249
Reply from 192.36.125.18: bytes=32 time=815ms TTL=249
Reply from 192.36.125.18: bytes=32 time=601ms TTL=249
Reply from 192.36.125.18: bytes=32 time=774ms TTL=249
Reply from 192.36.125.18: bytes=32 time=1610ms TTL=249
Reply from 192.36.125.18: bytes=32 time=763ms TTL=249
Reply from 192.36.125.18: bytes=32 time=160ms TTL=249
Reply from 192.36.125.18: bytes=32 time=1031ms TTL=249
Reply from 192.36.125.18: bytes=32 time=167ms TTL=249
Reply from 192.36.125.18: bytes=32 time=150ms TTL=249
Reply from 192.36.125.18: bytes=32 time=138ms TTL=249
Reply from 192.36.125.18: bytes=32 time=148ms TTL=249
Reply from 192.36.125.18: bytes=32 time=179ms TTL=249
Reply from 192.36.125.18: bytes=32 time=178ms TTL=249
Reply from 192.36.125.18: bytes=32 time=258ms TTL=249
Reply from 192.36.125.18: bytes=32 time=299ms TTL=249
Reply from 192.36.125.18: bytes=32 time=1178ms TTL=249
Reply from 192.36.125.18: bytes=32 time=300ms TTL=249
Request timed out.
Request timed out.
Reply from 192.36.125.18: bytes=32 time=1111ms TTL=249
Reply from 192.36.125.18: bytes=32 time=1258ms TTL=249
Reply from 192.36.125.18: bytes=32 time=1217ms TTL=249
Reply from 192.36.125.18: bytes=32 time=221ms TTL=249
Reply from 192.36.125.18: bytes=32 time=352ms TTL=249
Ping statistics for 192.36.125.18:
    Packets: Sent = 40, Received = 35, Lost = 5 (12% loss)
Approximate round trip times in milli-seconds:
    Minimum = 138ms, Maximum = 4427ms, Average = 1242ms
Responsen är si så där tongue
Funderar på att montera upp riktantennen, dock vet jag inte vart närmaste masten är, sitta och scrolla runt på pts karta är ingen höjdare.
Sen är huset nere i en dal/svacka om man ska säga så, så förhållandet är inte så bra från start, och sen skog 360grader tongue
Bytte till option icon 7.2 modem nu.
huawei e220 vs option icon 7.2
Huawei modemet rapporterade typ 35% signalstyrka.
Option modemet rapporterar 3% signalstyrka.
Surfandes känns snabbare med option modemet, fast hastigheten är lägre.
Bättre response i det.
