Tråd: Firmware upgrade till Novatel's Expedite EU870D anyone?
Jag har ett EU870D 3.6 som lär gå att uppgradera till 7.2?
Någon vet hur jag kan hitta denna firmware?
//Roger
Sv: Firmware upgrade till Novatel's Expedite EU870D anyone?
Är den rakt upp och ner ett novatel modem och inget oem från dell eller liknande så kan du maila dem så skickar de firmwaren.
Läste detta.
Originally Posted by Novatel Agents
Dear Chris,
Unfortunately I have not got good news for you. I received the following
email from Novatel engineers:
<Start Quote>
" We can't release firmware for Dell without Dell's approval.
Currently Dell does not see a business case for a 7.2 Mbps upgrade, even for modems they are currently selling...."
" The Dell module has a different hardware identifier, so the upgrade tool
will not recognize it and will fail to do anything.
The customer could buy a generic module from you..."
< End Quote >
So if you would have a generic Novatel Wirless EU870D than I could kindly
send you the firmware upgrade. But this fw upgrade does not work with the Dell identified modems as you see above.
If you want to order a generic module than you can find the modem here:
[DELETED]
We ship worldwide by DHL!
Thanks
Hej Andreas,
Tack för ett supersnabbt svar smile
Tyvärr får jag säga att det är ett DELL OEM modem, antar att jag är fast med skiten då.
Tack för hjälpen.
MVH/Roger
