Tråd: Visa mer detaljerad signalinfo i Mobilepartner
Såg detta i ett Australiensiskt forum som bert02 har skrivit:
In C:\Program Files\Mobile Partner\config\PluginsConfig.xml
Locate the following lines:
</devices>
<common>
<plugin>
If not present, enable diagnosis capability by adding the following line under here:
<item name="DiagnosisPlugin" clsid="5D31EE0B-DA93-4641-BD21-7DCE3DB15D16"/>
In C:\Program Files\Mobile Partner\plugins\DiagnosisPlugin\DiagnosisConfig.xml
Edit each of the following diagnostic elements from “false” to “true” (along with any of the other fields that may take your fancy), or simply replace with these complete lines:
<tab name="Network status" show="true" resourceID="IDS_TAB_NETWORK_STATUS">
<item name="Network name" show="true" resourceID="IDS_ITEM_NETWORK_NAME"/>
<item name="Network type" show="true" resourceID="IDS_ITEM_NETWORK_TYPE"/>
<item name="Signal strength" show="true" resourceID="IDS_ITEM_SIGNAL"/>
<item name="RSSI" show="true" resourceID="IDS_ITEM_RSSI"/>
<item name="RSQUAL(BER)" show="true" resourceID="IDS_ITEM_BER"/>
<item name="RSCP" show="true" resourceID="IDS_ITEM_RSCP"/>
<item name="Ec/Io" show="true" resourceID="IDS_ITEM_ECIO"/>
<item name="Ec/No" show="true" resourceID="IDS_ITEM_ECNO"/>
<item name="Cell ID" show="true" resourceID="IDS_ITEM_CELLID"/>
After starting Mobile Partner you can view the reported information under Tools, Diagnostics, Network Status tab.
Note that the update refresh is very slow.
If you are not comfortable first make backup of the orignal files. If all goes pear shaped just re-install Mobile Partner & they will be recreated.
Testade detta och det fungerar
Sv: Visa mer detaljerad signalinfo i Mobilepartner
Jodå, kom lite mer info, och några nya rader visade unknown.
3 Senaste redigerad av jonasolof (2012-07-29 17:48:14)
Vilken info fick du fram? Har du testat på E392?
Min gamla installation Telia Mobile broadband listar inte E392. PLuggar jag in modemet i datorn startar istället Telia_Mobilt_bredband.exe, dvs på svenska. Finns under program Files. Där finns inget som kan öppnas som xml fil. Verkar som om programvaran är helt omskriven från Huaweis. Så jag fåt vänta tills Mobile Partner är installerat. Men då finns ingen vägledning vad man kan ändra på eller lägga till för att få fram mer info.
Moddar man den för mycket kan man döda modemet helt. Har nämligen lyckats galant med denna bedrift.
5 Senaste redigerad av plun (2013-05-22 20:06:50)
Jo att modifiera mjukvara har ju sina risker men funkar det inte ens att flasha om modemet ?
Tex med Elisa-firmwaret för E398 samt E392
http://www.elisa.fi/elisa/docimages/att … 0.B757.exe
Vore bra om du kunde göra ett inlägg om hur man flashar modemet och vad som vinns med ny fw för E392 och E398. Gärna separat så att det kan klistras separat.
Någon annan som råkat ut för att allt fungerar "perfekt" ända till modemet "kopplat upp sig" och då reverterar den tillbaka till ursprungsdatavisningen?
har försökt allt möjligt nu men kommer inte runt det här...
