1 Senaste redigerad av Sam (2012-03-13 10:44:55)
Tråd: Huawei E392
Efterträden har anlänt:  http://www.prisjakt.nu/#rparams=ss=huawei%20e392
Det står ingenting om vilka 4G/LTE frekvenser den stödjer för just denna specifiska modell: E392u-12.
Vi ser själva att den blir inte lika varm som E398. Vi har stöd för den på alla befintliga routrar, officiellt från och med firmware 5.0.16
Lite allmän info: http://www.huawei.com/ilink/en/about-hu … multi-mode
Tack
Sv: Huawei E392
Ser lite mer slimmad ut en E398 right?
http://imup.se/t/LZYIuTphmT.jpg
The E392 mainly supports the following features:
 LTE 2600MHz/2100MHz/1800MHz/900MHz/DD800MHz, DC-HSPA+/HSPA+/UMTS
2100MHz/1800MHz/900MHz, GSM/GPRS/EDGE
850MHz/900MHz/1800MHz/1900MHz
 Support LTE 2600 10M/20M bandwidth
 Support LTE 2100 5M/10M bandwidth
 Support LTE 1800 15M/20M bandwidth
 Support LTE 900 5M/10M bandwidth
 Support LTE DD800 5M/10M bandwidth
 LTE 2×2 MIMO
 LTE uplink data service of up to 50Mbps
 LTE downlink data service of up to 100Mbps
 HSPA+ data service of up to 42Mbps(Dual carrier)
 HSDPA/HSPA+ Equalizer and receive diversity(TYPE 3)
 HSPA+ data service of up to 21Mbps(64QAM)
 HSUPA data service of up to 5.76Mbps
 HSDPA data service of up to 14.4Mbps
 UMTS PS domain data service of up to 384 kbps
 EDGE packet data service of up to 296kbps on DL with MSC33
 GPRS packet data service of up to 85.6 kbps
 CS domain data service based on UMTS and GSM
 SMS based on CS/PS domain of GSM and WCDMA
 WCDMA/GSM SMS service
 Prepared for LTE SMS over SGs service, but not activated
 Support LTE intra-frequency handover, inter-frequency handover will be
supported by firmware upgrade later
 Support LTE and UMTS inter-RAT idle mobility, LTE and GERAN inter-RAT idle
mobility will be supported by firmware upgrade later
3 Senaste redigerad av Sam (2012-03-13 11:43:29)
Sv: Huawei E392
Snygga spex vad gäller alla olika frekvenser! Står inget om TD-LTE (TDD), men det här räcker för Telia/Telenor/Tele2.
Den saknar swivel kontakt på USB, men modemet i sig är betydligt svalare än TreNittiÅttan i alla våra tidigare tester. For sure.
http://img855.imageshack.us/img855/7785/huaweie392andhuaweie398.jpg
Sv: Huawei E392
nice, äpple blank istället för S grått  wink
Sv: Huawei E392
Har den 2 utgångar för extern antenn ?
Sv: Huawei E392
Sv: Huawei E392
ok....
Har ni provat den med 4gr?
Sv: Huawei E392
Kör den dagligen.
Sv: Huawei E392
Sam skrev:
använder den då samma externa antenn för mottagning & sändning ?
Sv: Huawei E392
Körde den med antenn innan och uppfarten påverkas men inte mycket. Tror att den är enkelriktad dvs endast nerfart.
3G Telenor 16 Mbps i mobilen
4G Tre
Fiber 1000 Mbps
Sv: Huawei E392
Någon som har koll på hur jag låser upp mitt E392 som är låst till Telia i dagsläget? Finns överlag lite info om detta på nätet.
Sv: Huawei E392
Jag har ett Huawei E392 som jag kopplat en extern MIMO antenn till. På modemet finns två antennanslutningar så vitt jag kan förstå. Den ena sitter under samma lucka som Micro SD kortet den andra har en egen lucka.
Sv: Huawei E392
dc-unlocker har det i releasen som kom för ca en vecka sedan.
http://www.dc-unlocker.com/
14 Senaste redigerad av fredrikarvidsson (2012-06-11 20:26:34)
Sv: Huawei E392
Jag behöver hjälp!
Jag har problem med ett Telenor som kopplar ner! Har 90-99% signalstyrka i programvaran men i Windows är det 2 av 5 staplar.
RSSI visar: -87dBm
Huawei E392 har uttag för 2st externa antenner. Vilken extern antenn skall man köpa?
http://www.tradera.com/12-dbi-3g-modem- … _157639037
Är den bra eller kass? Passar den?
Tacksam för svar
Sv: Huawei E392
2 ut av 5 staplar bör nog stämma eftersom -87 dBm är 25% RSSI.
0% =  -113 dBm
1% =  -112 dBm
2% =  -111 dBm
3% =  -110 dBm
4% =  -109 dBm
5% =  -108 dBm
6% =  -107 dBm
7% =  -106 dBm
8% =  -105 dBm
9% =  -104 dBm
10% =  -103 dBm
11% =  -102 dBm
12% =  -101 dBm
13% =   -99 dBm
14% =   -98 dBm
15% =   -97 dBm
16% =   -96 dBm
17% =   -95 dBm
18% =   -94 dBm
19% =   -93 dBm
20% =   -92 dBm
21% =   -91 dBm
22% =   -90 dBm
23% =   -89 dBm
24% =   -88 dBm
25% =   -87 dBm
26% =   -86 dBm
27% =   -85 dBm
28% =   -84 dBm
29% =   -83 dBm
30% =   -82 dBm
31% =   -81 dBm
32% =   -80 dBm
33% =   -79 dBm
34% =   -78 dBm
35% =   -77 dBm
36% =   -75 dBm
37% =   -74 dBm
38% =   -73 dBm
39% =   -72 dBm
40% =   -70 dBm
41% =   -69 dBm
42% =   -68 dBm
43% =   -67 dBm
44% =   -65 dBm
45% =   -64 dBm
46% =   -63 dBm
47% =   -62 dBm
48% =   -60 dBm
49% =   -59 dBm
50% =   -58 dBm
51% =   -56 dBm
52% =   -55 dBm
53% =   -53 dBm
54% =   -52 dBm
55% =   -50 dBm
56% =   -50 dBm
57% =   -49 dBm
58% =   -48 dBm
59% =   -48 dBm
60% =   -47 dBm
61% =   -46 dBm
62% =   -45 dBm
63% =   -44 dBm
64% =   -44 dBm
65% =   -43 dBm
66% =   -42 dBm
67% =   -42 dBm
68% =   -41 dBm
69% =   -40 dBm
70% =   -39 dBm
71% =   -38 dBm
72% =   -37 dBm
73% =   -35 dBm
74% =   -34 dBm
75% =   -33 dBm
76% =   -32 dBm
77% =   -30 dBm
78% =   -29 dBm
79% =   -28 dBm
80% =   -27 dBm
81% =   -25 dBm
82% =   -24 dBm
83% =   -23 dBm
84% =   -22 dBm
85% =   -20 dBm
86% =   -19 dBm
87% =   -18 dBm
88% =   -17 dBm
89% =   -16 dBm
90% =   -15 dBm
91% =   -14 dBm
92% =   -13 dBm
93% =   -12 dBm
94% =   -10 dBm
95% =   -10 dBm
96% =   -10 dBm
97% =   -10 dBm
98% =   -10 dBm
99% =   -10 dBm
100% =   -10 dBm
Sv: Huawei E392
0% =  -113 dBm
1% =  -112 dBm
2% =  -111 dBm
3% =  -110 dBm
4% =  -109 dBm
5% =  -108 dBm
6% =  -107 dBm
7% =  -106 dBm
8% =  -105 dBm
9% =  -104 dBm
10% =  -103 dBm
11% =  -102 dBm
12% =  -101 dBm
13% =   -99 dBm
14% =   -98 dBm
15% =   -97 dBm
16% =   -96 dBm
17% =   -95 dBm
18% =   -94 dBm
19% =   -93 dBm
20% =   -92 dBm
21% =   -91 dBm
22% =   -90 dBm
23% =   -89 dBm
24% =   -88 dBm
25% =   -87 dBm
26% =   -86 dBm
27% =   -85 dBm
28% =   -84 dBm
29% =   -83 dBm
30% =   -82 dBm
31% =   -81 dBm
32% =   -80 dBm
33% =   -79 dBm
34% =   -78 dBm
35% =   -77 dBm
36% =   -75 dBm
37% =   -74 dBm
38% =   -73 dBm
39% =   -72 dBm
40% =   -70 dBm
41% =   -69 dBm
42% =   -68 dBm
43% =   -67 dBm
44% =   -65 dBm
45% =   -64 dBm
46% =   -63 dBm
47% =   -62 dBm
48% =   -60 dBm
49% =   -59 dBm
50% =   -58 dBm
51% =   -56 dBm
52% =   -55 dBm
53% =   -53 dBm
54% =   -52 dBm
55% =   -50 dBm
56% =   -50 dBm
57% =   -49 dBm
58% =   -48 dBm
59% =   -48 dBm
60% =   -47 dBm
61% =   -46 dBm
62% =   -45 dBm
63% =   -44 dBm
64% =   -44 dBm
65% =   -43 dBm
66% =   -42 dBm
67% =   -42 dBm
68% =   -41 dBm
69% =   -40 dBm
70% =   -39 dBm
71% =   -38 dBm
72% =   -37 dBm
73% =   -35 dBm
74% =   -34 dBm
75% =   -33 dBm
76% =   -32 dBm
77% =   -30 dBm
78% =   -29 dBm
79% =   -28 dBm
80% =   -27 dBm
81% =   -25 dBm
82% =   -24 dBm
83% =   -23 dBm
84% =   -22 dBm
85% =   -20 dBm
86% =   -19 dBm
87% =   -18 dBm
88% =   -17 dBm
89% =   -16 dBm
90% =   -15 dBm
91% =   -14 dBm
92% =   -13 dBm
93% =   -12 dBm
94% =   -10 dBm
95% =   -10 dBm
96% =   -10 dBm
97% =   -10 dBm
98% =   -10 dBm
99% =   -10 dBm
100% =   -10 dBm
Tack! Vet du om Huawei E392 har support för antenner med uttag CRC9?
17 Senaste redigerad av fredrikarvidsson (2012-06-11 21:18:36)
Sv: Huawei E392
Är det CRC9 eller TS9-uttag för extern antenn till Huawei E392?
Sv: Huawei E392
E392 har samma som E398
19 Senaste redigerad av fredrikarvidsson (2012-06-11 21:46:56)
Sv: Huawei E392
Passar denna i modemet? eller måste jag ha en adapter? Har ingen aning vad E398 eller E392 har för uttag...
http://www.dealextreme.com/p/13dbi-3g-o … 966?item=4
Sv: Huawei E392
Varför skaffar du ett 3G-frekvens antenn till ett 4G modem?
Det här är sånt som täcker alla 4G frekvenser i Sverige, från 800MHz till 2600MHz:
http://www.kjell.com/sortiment/dator-kr … enn-p30055
21 Senaste redigerad av fredrikarvidsson (2012-06-11 22:00:08)
Sv: Huawei E392
Köpte ett nytt olåst Huawei E392 på Tradera för 500kr. Ganska dumt ändå, man kan väl inte beställa ett 4G simkort gratis eller?
Sv: Huawei E392
Jo vissa operaörer har gratis sim, bara att ringa eller kolla deras webb, men lösa sim utan bindningstid brukar dom gömma i en vrå....
För dom föredrar långa bindningstider så dom kan använda dom som säkerhet vid lån...
Sv: Huawei E392
Hittar inte information vilket uttag Huawei E392 / E398 har för uttag till externantenn? är det ts9 eller?
Sv: Huawei E392
http://www.communica.se/index.asp?artikel=4110805
Sv: Huawei E392
Bör vara CRC9
