Tråd: Huawei E960 HSDPA Wireless Gateway
http://www.bandwidth.mina-filer.com/imgs/9/0/e960banner.jpg
http://www.bandwidth.mina-filer.com/imgs/9/0/e960.gif
http://www.huawei.com/policy/simpleres. … pe=abouthw
Highlight
    * Supporting two working modes of the wireless gateway and USB modem
    * Supporting the HSDPA at a rate of 3.6/7.2 Mbit/s for downlink and 384 Kbit/s for uplink
    * Built-in WCDMA and WLAN high gain antenna, which supports receiving diversity and equalizer
    * Supporting Web-based management, parameter presetting, and plug-and-play
    * Ultrathin and artful ID
    * User-friendly design of indicators
    * Supporting three placement methods: desktop, desktop inclining, and wall-mounted
Dimensions (Length × Width × Height) 155 mm × 115 mm × 28 mm
Weight <500 g
External Interfaces
Four LAN interfaces for the RJ 45
One telephone interface for the RJ11
WLAN: maximum of 32 users
Power supply interface and USB interface multiplex
Indicators
One power supply indicator
One signal type indicator
One indicator for WLAN in service
One signal intensity indicator
Four Ethernet interfaces, each Ethernet interface has a LINK/ACTIVE indicator
Antenna: Built-in antenna
UIM: Supports the R-UIM mode
Operating System (OS): Windows 2000, Windows XP, Windows Vista, and MAC OS
Band Class
Supports HSDPA/UMTS 2100 M
Supports GSM/GPRS/EDGE 850/900/1800/1900 MHz
Technical Standards
1. HSDPA/WCDMA: 3GPP R5 2004/06
2. GSM/GPRA/EDGE: 3GPP R99 2003/12
Functions
Functions in wireless gateway mode:
    * High speed data
    * Voice
    * Route
    * LAN and WLAN access
    * Web-based local management and maintenance
Functions in USB Modem mode:
    * High speed data
    * Short message
    * Phone book
    * Automatic installation, and plug-and-play
    * The power is supplied through the USB from the PC. Thus, no external power supply is required.
Others
    * Passed certifications such as EMC, SAR, CE, ROHS, and GCF
    * Reliable quality and good compatibility
Sv: Huawei E960 HSDPA Wireless Gateway
Ingen extern antenn för 3G eller WLAN......ajdå.
Jag undrar om det finns någon som vet om det finns en riktig användarmanual till Huawei E960 HSDPA Wireless Gateway ??? till skillnad av den ynkliga Quick Start häftet man får av Telia....
Telias support är urdålig på denna modell... Finns det även någon ny firmware till denna router ?
Sen undrar jag också hur man krypterar WLANET, vilket inte supporten på telia kan...
Jag är novis på hur 3G/WLAN fungerar och vore tacksam på tipps.
Kan inte hjälpa dig så mycket.
Men någon slags firmware tycks finnas här.
http://www.huawei.com/mobileweb/en/doc/ … mp;id=2625
Du får nog koppla in dig på lanet och sedan kolla vilken defualt gateway du har.
T.ex. 192.168.0.1
Och sedan ansluta till webinterfacet på t.ex. http://192.168.0.1/
Och logga in och sedan sätta upp rättigheter på wlan och sådant.
Och det är nog där inne du uppgraderar firmware också.
Edit:
Glöm de jag babbla om, hitta en 57 sidors manual där det säkert står i.
http://www.mobilabredband.se/files.php? … -guide.pdf
Jag bugar och tackar Andreas...  Jag har själv försökt hitta en bra ingående manual till Huawei E960 på internet utan resultat...
I manualen du tippsade mig om står allt jag undrade över..
Mvh. Roy smile
Tjena,
Jag har lånat en E960 från polare som köpte en unbranded model från ClickOK.se. Jag har testat den nu, och förutom att routern har inga externa antenner till 3G och WLAN, jag har märkt par grejer som är helt cookoo.
- Visar stark 3G signal även när jag vet att det är inte så himla bra signal där jag bor (Huawei E220 brukar visa runt 40%).
- Ingen Port-Forwarding.
- Ingen UPnP funktion i firewallen
- Fan.........ingen sorts firewall
- Ingen remote access
- Ingen DynDNS-sorts tjänster
- Man måste mata in PIN kod efter varje omstart (värsta annoying feature)
Är det bara jag som tycker att det här är en överglorifierad modem med trådlös LAN?
Jag använde ett Option GTMAX 7.2mbps ready kort innan och hade mellan 3 och 4 pinnar av 5 med E960 har jag 4 av 5.
port forward finns på Security under Virtual Server.
remote access finns på Security under Remote Management.
det går att avaktivera pinkoden på Advanced Settings under SIM Settings.
det enda jag saknar är DynDNS tjänster
Hej Mr. T,
Tyvärr så har jag inte dessa funktioner alls i min GUI!!!
Läs vad Huawei skriver till kunder i Saudi och Kuwait angående det här:  http://forum-hk.huawei.com/jive4/thread … orderStr=8
Har kollat överallt, men hittar ingenting lik det du specifierar. Som sagt, jag kör en unbranded variant, så jag borde ha det bästa, man skulle hoppas.
Jag har också en GT MAX kort, som visar 3 av 5 medan E960 visar 5 av 5.
Förresten....hur kan jag ha den fungerande i bilen? Den har bara en USB type-B plug.
Tack!
det följer med en kabel med 2 vanliga usb kontakter i andra änden
Har nyss beställt denna med Tre .ab.
Får jag bättre utdelning med denna i jämförelse med E220 & adhoc?
E 220 är ju trot allt 1 tusing billigare & framförallt smidigare på resande fot.
Vi hörs / p
11 Senaste redigerad av jonasolof (2008-11-08 16:06:00)
Som framgår av Huaweis svar i länken ovan finns det olika versioner av E960 beroende på hur operatörerna velat ha dem utformade. Telias version har uttatg för extern 3G antenn och en switch för att växla mellan extern och intern antenn. Men de har det nedbantade interfacet där man avlägsnat allt som har att göra med ingående trafik som port forwarding etc. Det är dock en router för den kan köra MAC-filtrering och blocka anslutna IP adresser.
Fullversionen har en rad till under advanced settings som heter Security. Manualen finns här:
http://images.bite.lt/bite/files/new/pu … ide_EN.pdf
För en användare som inte behöver DYNDNS och att kunna köra servrar bakom funkar Telias version bra. Extern antenn finns att beställa hos Telia, 349 kronor, artikelnummer 271 60 188
Huawei säljer också en router som heter B970 med samma utseende utvändigt inkl uttag för extern antenn. Även manualen visar samma förutom lite mer möjligheter på WLAN sidan så vitt jag såg som hastigast.
http://www.mobinil.com/aboutmobinil/Tec … ateway.pdf
Den är dock förmodligen också branded och kan ha funktioner bortplockade.
Med den yttre antennen får jag full signalstyrka både på 3 och Telia och nedlastningshastighet på 4-4,9
Kan du inte ta en bild på antenn kontakten, eller säga vilken sort det är?
Antennkontakten på routern är en standard SMA hona, alltså inte reverse polarity SMA. Verkar som om reverse polarity SMA och TNC används mest för WLAN.  På den en meter långa kabeln från antennen sitter så klart en standard SMA hane.
Det står väl för övrigt i pdf filen om antennen från Huawei/Telia som jag mailade till er.
En bild säger mer en 1000 ord smile
Hur infogar jag en jpeg-bild i mitt inlägg om den finns i min dator?
Du kan ladda upp bilden här och sen ta koden eller kopiera adressen hit sen smile
17 Senaste redigerad av jonasolof (2008-11-09 12:16:35)
Det står faktiskt SMA under kontakten men det är svårt att se.
http://www.bandwidth.mina-filer.com/imgs/137/0/e960smahona.jpg
den lilla slideswitchen ovanför ethernetuttaget till höger är ställd på intern antenn nu när jag kopplade bort den externa.
Antennen:
http://www.bandwidth.mina-filer.com/imgs/137/0/antenn4db.jpg
Magnetfot. Höjd 27 cm ca.
