Tråd: DOVADO 3GN firmware 4.1.3
http://www.dovado.com/3GN_Firmware.html
Update since 4.0.4
Overview
This is the first firmware update on the 3GN since the initial production firmware.
SMS
SMS->REMOTE CONTROL: "œConnection Up"  SMS now provides more info (feature only works when combined with Connection Tracker)
SMS->SETTINGS: Added extra methods of extracting received messages from the modem.
- Auto(default) (3GN tries to figure out if SMS is received to SIM or MODEM)
- SIM (Forces the 3GN to read incoming SMS from SIM and then move it to the 3GN memory)
- MODEM (Forces the 3GN to read incoming SMS from MODEM and then move it to the 3GN memory)
If there is problem with receiving SMS, then please try to force the router to SIM Mode / Modem Mode and then send a new sms to see if it has received it.
Modems with now functioning SMS:
Alcatel One Touch X030
Alcatel One Touch X060s
Huawei E182e (recommend USB modem firmware update for Swedish TRE customers)
Huawei E1820 (recommend USB modem firmware update for Swedish Tele2 customers)
Sony Ericsson MD300
Sony Ericsson MD400
NTP (Network Time Protocol)
Field available for custom entry of NTP server.
Daylight saving times available as an option.
NTP servers can be located on the LAN side of the router.
NTP servers can be either a host name or an IP address.
Ethernet WAN port
Resolved DHCP issue with Cisco networks, where the router doesn't receive an IP address when using DHCP.
Dynamic DNS
Password can now contain special characters such as !"#?=)(
E-Mail Notifications
SYSTEM->EMAIL: Resolved issue where settings were able to be saved if certain fields were left empty.
Remote Management
SYSTEM->REMOTE MANAGEMENT: Supports manual entry of whitelisted hostnames for remote access (besides IP addresses).
Sanity checks between port-forwarding rules and selected remote management port.
UPNP
LAN->UPNP: Ability to view which ports are presently used.
SYSTEM
SYSTEM->NETWORK SETTINGS: ICMP block : Ability to disable ping replies from outside.
SYSTEM
WLAN
Improved connection with Apple iPod Touch/iPhone.
New modems:
Supported USB Mobile Modems    Mobile Technology    SMS Support
4G-System XSStick W14    HSDPA    Yes
Huawei E122 ("3/Three/Tre")    HSUPA    Yes
Huawei E161    HSDPA    Yes
Huawei E1762    HSUPA    Yes
Huawei E510    HSUPA    Yes
Longcheer WM71    HSUPA    Yes
Nokia CS-10    HSUPA    Yes
Vodafone K3765    HSUPA    Yes
Vodafone (Huawei) K4505 (21Mbps down, 5.76Mbps up)    HSPA+    Yes
ZTE MF662 (OTE Greece, 21Mbps down, 5.76Mbps up)    HSPA+    No
ZTE MF668 (Rogers Canada, 21Mbps down, 5.76Mbps up)    HSPA+    No
Sv: DOVADO 3GN firmware 4.1.3
njah du, någon bättre mottagning på iphone 3GS blev det då inte, lägger iphonen på routern och den sitter kvar på en plupp i Wifi mottagning sad
annars, kul med uppdatering smile
är det här något som fungerar bättre på UMR'en?
var just för iphonens del jag skaffade 3GN'en sad
med telenor option GT max modem enligt routern.
men det är ett GIO225 enligt mig?
vad har du för firmware på din iPhone?
Jailbreakad 3.0.1
Vi fick väldigt bra resultat med 3.1.3
Apple har gjort massor av ändringar av wlan koden i senare firmwares.
Mvh
Mathias
Iphonens "allt i ett" chipp har stöd för en hel del saker som apple inte har aktiverat.
T.ex. 802.11n, Radio sändare och mottagare. Mycke synd. sad
Mvh
Mathias
men det ärkonstigt att jag aldrig haft problem med någon annan wlan anslutning?
9 Senaste redigerad av Mathias (2010-02-26 15:02:05)
Nja, Läser du på apples support forum så är massor av folk som har problem med sina Iphones mot olika routrar, Det är chipset kompabilitets issues. Kan vara så att den mjukvaran i  din 3.0.1 har problem mot det chipsetet som sitter i våran router, Och att apple i senare mjukvara gjort ändringar.
Vet dock att andra fick problem med sina 3.1.3 Ihpones mot andra routrar efter att de uppgraderat.
Problemet är att Apple säger det är inge fel på iPhone det funkar ju om man kör Airport Express :-)
Har du normal räckvid om du kör med en laptop?
//Mathias
