Tråd: Howto: Huawei's modem med Mac OS X Leopard
http://reviews.cnet.com/i/ss/32004253/32004253_OVR_440.jpg
Huawei har släppt drivisar för Max OS X Leopard.
Du kan ladda ner dem här.
http://www.tre.se/upload/3MobiltBredban … 2010.5.zip
Det finns en hake, du måste inaktivera pinkoden för sim kortet.
Du kan göra det genom att koppla in modemet med simkortet i en Windows dator eller stoppa in det i en mobil och inaktivera det på så vis.
En pdf guide:
http://www.tre.se/upload/3MobiltBredban … .5_3SE.pdf
This is for sure not a preferred user experience, however it is a quick fix. We are working on a 3Connect dashboard also for Mac that will have the same functionality as for Win.
Please give feedback if you think this quick fix is good enough for now, the alternative is to continue to not to support Leopard.
Attached is Drivers and the guide how to set the connection up for the first time. (Attached is one guide for Sweden and one for Denmark).
The Driver attached are valid for following products:
*Huawei E220
*Huawei E630
*Huawei E270
*Huawei E870
NOT E960.
